Slater
| posted on 13/11/08 at 02:41 PM |
fan and fan switch
Hello
What order should I wire these up?
A - 12V Feed, Fan, Fan Switch, Earth
or
B - 12 V Feed, Fan Switch, Fan , Earth
Mr Whippy
| posted on 13/11/08 at 02:43 PM |
B but both work the same
not another thing going to work today? your going to be well plastered at this rate...
[Edited on 13/11/08 by Mr Whippy]
| posted on 13/11/08 at 02:48 PM |
Yup. It makes no difference whether you switch the +ve supply or the -ve supply..... Unless the fan body is earthed in which case you wouldn't
want to switch the negative (you'ld have a constant +ve feed and an earthed fan body)....
Mr Whippy
| posted on 13/11/08 at 02:53 PM |
New avatar for you once you have completed the wiring and celebrated with a few glassed of the Islay malt...
Slater
| posted on 13/11/08 at 03:19 PM |
Mr Whippy, you have too much time on your hands!
Mr Whippy
| posted on 13/11/08 at 03:24 PM |
yeah I know, currently designing a huge bean bag I’m going to make for Miss Whippys Christmas since my schedules are a work of art and I'm
upto date
r1_pete
| posted on 13/11/08 at 03:29 PM |
Job Done
big_wasa
| posted on 13/11/08 at 03:53 PM |
I am going with A) I had an amp meter hooked up and decided I didnt need a relay
Myke 2463
| posted on 13/11/08 at 07:20 PM |
Ford usually use "A" good enough for me. No relay used on my car, just a fuse.
