orbital
| posted on 28/12/08 at 02:14 PM |
Side/Headlight Rocker Switch
Hi All,
Time for my monthly "How the f**k do I wire this" question.
I'm trying to work out how to wire my Durite off/side/head switch. I've got the wiring diagrams but it's not making any sense to me. I
know this is tantamount to blaspheming on here, but I wish I'd bough a completed car now!
I have these connectors on the stalks (which I'm removing hence the post).
And I'm trying to replace the side light/head light part on the stalks with this switch
There are only three pins on the back of the switch and none of them are marked in anyway as I can see. Any help would be greatly appreciated.
Dave
prawnabie
| posted on 28/12/08 at 02:57 PM |
Use a multimeter-
one pin will be the live feed in
one pin will be the side lights feed out
one pin will be the sidelights and headlights feed out
HTH
Shaun
big_wasa
| posted on 28/12/08 at 03:30 PM |
If you are using the sierra stem for the indicators you maybe better of going switched earth ?
either way its still very easy. give me a shout if you are using the sierra indicator stem and I will do you a wiring diagram
omega 24 v6
| posted on 28/12/08 at 04:15 PM |
Well first off anything possible. So basically at the moment with the sierra stalks and switches it works as follows.
When you put on the side lights the red 30 joins to the slate 58 and bingo you have lights. Then when you put the switch to head lights the red 30
STILL stays joined to the slate 58 BUT the brown 31 then also joins to the black/red 56 which in turn is a negative switch for the headlight relay
(dip beam) this relay has a seperate LIVE feed from the fuse box.
It looks complicated but like I say it would be posssible given the right switches. I have a line diagram of the sierra switches in autocad format I
could email to you if you want.
orbital
| posted on 28/12/08 at 05:06 PM |
Hi Gary,
I've got you line diagram mate and I'm still having trouble I just can't get my head round this wiring at all. I'm really
starting to think I should get someone to do this for me as I really don't want to set fire to the loom because I've been an arse and done
something wrong.
Wasa,
I'm replacing all the stalks from the Sierra column with switches (oh how I regret that decision now!). I've managed to replace the
ignition barrel with a on/off key and a start button and also the indicator stalk with an on/off/on switch (with the help of Gary above). But this
side/headlight switch is really starting to do my head in.
Dave
omega 24 v6
| posted on 28/12/08 at 06:04 PM |
Look at the line diagram again mate. Visualize the switch in your head and realize that the diagram shows the switches in the off position. The centre
part of the switch drawing show which connectors join up as you move the switch to position 1 or 2 (light switch) the dip/main beam/ flash switch is
the same it's in the dip beam postion.. Push it down to change which relay is earthed (changes from dip to main beam) pull it up and as the the
main beam relay has power at all times and you're earthin it the headlights flash.
orbital
| posted on 29/12/08 at 02:11 AM |
OK, so using your line diagram the light switch has these three possible positions:
Is that correct? If so, how does that equate to the three pins on the back of my switch? I'm still not sure how exactly which wire goes to which
pin. Sorry for being dim mate!
Dave
omega 24 v6
| posted on 29/12/08 at 09:09 AM |
Yep there you go you've got it right. As for your switch then I'd need a diagram of the internals or a description of what it is (website
etc would do probably). If it's an on off on then there are possibilities for it to work but it'd mean adapting/altering the relay wiring
for the head light as well. I presume your keeping the main beam and flash on the stalks??
On my way out for the day now but I'll check back later on tonight.
orbital
| posted on 29/12/08 at 01:08 PM |
Cheers for your help mate I really appreciated it.
The switch is the one above a Durite off/on/on. The only thing is says on the packaging is "Part 0-645-00 Switch Metal Dolly 3 Way
Off/Side/head" I've had a search round this morning and can't find squat about it's internals or even which pin does what.
My intention is to remove the stalks completely, so I was going to put the main beam and flash onto another switch. Actually, what I thought of doing
was to put the main beam onto a push button (latching) switch. So you can just push it on and off to flash, or just leave it on for full beam. Do you
think that would be OK?
Dave
