Slowmotion
posted on 16/1/09 at 02:28 PM |
Can anyone explain HDMI Lead Compatibility
Getting Frustrated with Samsung.
We've just bought a new DVD Recorder with upscaling and already have an HD Ready Samsung TV.
Bought a 1.3 HDMI Lead, connected up but the TV doesn't seem to recognise the HDMI Port.
Samsung say I need an older spec 1.1 or 1.2 lead but everyhing I read on line says the 1.3 version is backwardly compatible.
Does what Samsung say make sense (TV is 2-years old) and if it does how could I get a 1.1 or 1.2 soec lead?
Any help would be greatfully received,
John.
Mr Whippy
posted on 16/1/09 at 02:42 PM |
Do you remember when we were happy with just having a colour tv? (I had a BW one I got off my folks, it could run off the car battery too, I mind
watching yellow (shades of grey) submarine on it ) or that the computer didn't chew the tape up this time trying to load a game. Oh happy
days
[Edited on 16/1/09 by Mr Whippy]
neilj37
posted on 16/1/09 at 02:43 PM |
The leads are backwardly compatible but sounds like your tv is not !! If your blu-ray player is 1.3 compatible it may be trying to send the audio
signal through the hdmi lead to the tv which it cannot decode. Have you tried changing the settings in the dvd so that the audio goes out of the
optical port instead of the hdmi.
[Edited on 16/1/09 by neilj37]
posted on 16/1/09 at 02:48 PM |
colour TV?
Luxury. All we had was carboard box to share between all one hundred and fifty of us.
Mr Whippy
posted on 16/1/09 at 02:53 PM |
colour TV?
that's indeed a very small cardboard house, it's just as well you didn't have a tv cos there'd be no more room inside...
Humbug
posted on 16/1/09 at 03:01 PM |
colour TV?
??? probably quite a large cardboard house if there was room for 150 people
Mr Whippy
posted on 16/1/09 at 03:35 PM |
colour TV?
in those days little was thought about queuing for your turn to sleep in the box...these days they call it hot bedding
posted on 16/1/09 at 03:36 PM |
1.1, 1.2 and 1.3 spec cables....
From what I know about HDMI Cables (which isn't much), the only difference is the specification of the transfer rates. 1.3 being the
quickest.
However, there (apparently) were many 1.1 and 1.2 cable swhich didn't meet Spec., but this doesn't help you.
May you have a faulty 1.3 HDMI Cable perhaps? Can you try a neighbours or anything that you know works?
Sorry I cant be of more help...
neilj37
posted on 16/1/09 at 03:46 PM |
quickest.
I thought the difference was that the V1.3 cables could now transmit the audio signal whereas the V1.1 & V1.2 could not.
vinny1275
posted on 16/1/09 at 03:53 PM |
I didn't think the cables themselves changed in spec 1.3 - rather that the HDMI spec was altered to allow for online updates to video and audi
codecs, that kind of thing. (I could be completely wrong with that).
Have a look at your DVD player's instructions, see if you can find a way of transmitting 1.1 or 1.2 spec to work with your TV...
liam.mccaffrey
posted on 16/1/09 at 04:49 PM |
switch the ends around you might be surprised
It has solved a ton of AV problems for me in the past
Build Blog
Build Photo Album
chrism
posted on 16/1/09 at 05:11 PM |
Is ther not an option on the dvd player to output video via hdmi.
I know certain devices wont output scart/av and hdmi at the same time, so they come by default set to scart and then you have to change to hdmi
manually.
The virgin V+ boxes do this, more annoyingly you had to plug it into scart and hdmi then go in on your tv via scart and then switch it to use hdmi
then change your tv to hdmi and read the message that tells you to press ok to accept in less than 10 seconds otherwise hdmi gets diabled again. My
friends had this problem cause the virgin guy didnt do it for them and didnt mention that there is a time limit after switching to ok.
A little hard work never killed anyone, but why take the risk!
The Great Fandango
posted on 16/1/09 at 05:28 PM |
Ultimately, it might just be a knackered cable. Can you borrow another to try? (preferably a short one to prove it's not the length causing the
issue).
As mentined, also try reversing which way round it is plugged in.
Don't ask why, but I have over 15 different HDMI cables in the house (ranging from 0.25m to 35m). All work perfectly well and most of them were
as cheap as chips off eBay. Admittedly, the 35m one requires a 'repeater' (booster) to stop an intermitant fault.
Been fairly lucky in many respects. Several of my HDMI cable are sunk into the wall and are now plastered over. They appear to be holding up well.
HDMI is the way foward!
[Edited on 16/1/09 by The Great Fandango]
He Who Dies With The Most Toys Dies The Happiest
posted on 16/1/09 at 05:46 PM |
Hi - I got most information from HERE so I can really only comment on
that.
Saying that - on my HDMI Monster Cable it does say TV one end and Output on t'other so maybe swapping the cable around my work.
Slowmotion
posted on 16/1/09 at 06:56 PM |
Thanks everyone for your suggestions.
Not sure why but I disconnected the HDMI lead and connected the TV to the DVD by SCART which allowed me to see the DVD set up menu and get it working
but without any upscaling.
I then re-connected the existing 1.3 HDMI lead and IT WORKS!
Was really annoying me but I can relax now.
Liam
posted on 18/1/09 at 08:02 AM |
Was your DVD player perhaps upscaling to 1080p, which is possibly not supported by your TV?
Liam
