jlparsons
posted on 8/2/09 at 09:47 PM |
MX-5 gearbox
What's the gearbox in the mazda mx-5, and has anyone used it either with the donor engine or with duratec/zetec?
Beats me why this doesn't come up more, mazda/ford engines being often interchangeable as they are. I know mnr do a mx-5 based car but
haven't noticed anyone else going wit it.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
dave1888
posted on 8/2/09 at 09:56 PM |
Thats the upgrade im doing now this is quite a good website.
mazda
l0rd
posted on 8/2/09 at 11:01 PM |
i will be using an mx5 as a donor.
jlparsons
posted on 8/2/09 at 11:30 PM |
Anyone used the mx-5 gearbox with a duratec/zetec?
dave1888
posted on 8/2/09 at 11:32 PM |
Not that i know of, but apparently the mazda 6 speed fits straight on to the duratec.
posted on 9/2/09 at 08:27 AM |
Mazda 5 or 6 speed mount up to the Duratec as its a Mazda design unit.
They do not fit zetec's. Yamaha designed but Ford manufatured with corporate mountings.
JAG
posted on 9/2/09 at 08:28 AM |
There's me and Keith Tanner as well.
I used the 5 speed gearbox on the 1.6 litre Mazda engine.
Justin
road warrior
posted on 9/2/09 at 12:17 PM |
The early 5-speed will not fit the Duratec. You need the later NC box.
I am using the current NC MX5 2.0L and the matching 5 speed.
locost_bryan
posted on 10/2/09 at 03:23 AM |
What matching 5-speed? Thought only the current 6-speed fitted the MZR/Duratec.
5-speed and previous 6-speed only fitted the B-series (1.6 and 1.8).
The original 5-speed is the Mazda M-series, which was also fitted to most sub 2-litre rwd Mazda cars and vans (but with wider ratios).
Check out www.solomiata.com for a great article about the rwd Mazda gearboxes.
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
road warrior
posted on 10/2/09 at 10:02 AM |
Hi Bryan
From Wiki;
For the USA, the engine is the new 16-valve, 2.0 L (120 cu in) MZR I4, producing 166 bhp (124 kW) and 140 ft·lbf (190 N·m) coupled to either a 5-speed
or a 6-speed manual transmission or 158 bhp (118 kW) with the optional 6-speed automatic transmission. A limited slip differential is available with
the 6-speed option. In Australia the 2.0 L (120 cu in) MZR is offered, rated at 118 kW (158 bhp) and 188 N·m (139 ft·lbf) and the 6-speed transmission
and LSD are standard. In Europe, two engines are offered: the 2.0 L (120 cu in) MZR rated at 160 bhp (120 kW) and 188 N·m (139 ft·lbf), coupled to the
6-speed manual transmission; and a new 1.8 L (110 cu in) MZR, rated at 126 bhp (94 kW) and 167 N·m (123 ft·lbf), coupled to the 5-speed manual
transmission.
So yes, it does exist but is not standard for Aus/Nz.
locost_bryan
posted on 17/2/09 at 01:33 AM |
If it's the "old" M-series 5-speed, then yippee!!!!!! ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Shame it doesn't have a separate bellhousing, otherwise that would make the Duratec/MZR a simple swap on to the old 5-speed.
Bryan Miller
Auckland NZ
Keith Tanner
posted on 13/5/09 at 01:22 AM |
Late to the party here - there's a 5-speed for the NC MX-5 (the 2006 and later model) that uses the same internals as the previous models, but
the case is different. You'll want one of those to mate to your Duratec. The 6-speed has had some problems breaking shift forks in racing. I
haven't heard if it's a problem for street cars, but take it a bit easy on the 3-4 shift just to be sure...
www.slowcarfast.com
posted on 13/5/09 at 07:52 AM |
Another 2 penith, the 6 speeder is way heavier than the 5 cog box and not worth the extra cog imo.
Sandspeed
posted on 13/5/09 at 09:29 AM |
ranger
Just to add to the mix, would the gearbox from an I4 ranger work???
clutch_kick
posted on 13/5/09 at 05:58 PM |
So if I decided to Go ahead with the 1.6 engine, will the gearbox match up to the new 2.0L engine and the engine mounts?
