Author: Subject: Sierra v Cortina Column
cheetah
posted on 10/2/09 at 10:24 AM Reply With Quote
Was wondering if someone in the land of Sierra could tell me if the bottom of the Sierra Column is triangular and the same dimensions as a (i think) Mk 3/4 Cortina - we called them TC/D down here in Oz. I wanted to know if I could use a coupling like this.. Rescued attachment RD850Prod.jpg
twybrow
posted on 10/2/09 at 10:53 AM Reply With Quote
Cant confirm dimensions, but it is triangular!
robinj66
posted on 10/2/09 at 05:58 PM Reply With Quote
the triangular bits at the bottom of the columns are the same size
Thierry
posted on 11/2/09 at 08:48 AM Reply With Quote
Hi Cheetah,
yes they are the same i have a sierra column in my avon and i have a cortina rack somewhere in the shed and they bolt up.
I am also down under but further up on the gold coast under maudsland in ausclubbies
Cheers Thierry
cheetah
posted on 11/2/09 at 09:22 AM Reply With Quote
Thanks Thierry
im also on ozclubbies (tando) just trying to refine some elements of the Puma I am building. using a sierra to escort spline coupling I can then run a simple shaft with escort spline both ends down to the rack, no welding etc to worry about.
Tony
