wescottishmatt
| posted on 16/2/09 at 10:06 AM |
ZX10r Clocks - Stuck Rev Counter (and a new builder).
Hello everyone. I'm new to posting here but I've been checking this forum since deciding to Build a MAC 1 with a zx10R engine. (Heavily
influenced by the 'Bigrich'syndrome).
I should be picking up the kit this weekend so lots of happy days ahead.
Managed to get hold of a set of ZX10R clocks (e-bay special) but when they've arrived the rev counter is stuck at 3000rpm. As I can't
really test them on the car yet can anyone tell me if this is just a minor problem or a major issue?
I've attached a picture but if its not there its also in my photo archive.
Mr Whippy
| posted on 16/2/09 at 10:57 AM |
Have you tried tapping it lightly with a hammer, seriously often gauges will just free themselves
One other thing that comes to mind is it came from a crashed bike and that the engine speed it was doing at the time, which might indicate the gauge
is damaged internally from the impact
  10r clocks - stuck tacho
[Edited on 16/2/09 by Mr Whippy]
wescottishmatt
| posted on 16/2/09 at 11:07 AM |
Not tried tapping it with a hammer (yet). The pic on ebay showed it connected up and with the needle sat at 0rpm
I've got a copy of the 10r service manual so might try connecting it up and putting power through it to see if it resets (hopefully).
Mr Whippy
| posted on 16/2/09 at 11:28 AM |
don't trust pictures on computers when buying stuff, they are far too easy to alter
mr_pr
| posted on 16/2/09 at 11:39 AM |
It will be fine. If you kill the power to the clocks the needle just stays where it is at the time.
I am sure when you connect it to power it will do its checks and return to zero...
My Build Progress
PAUL FISHER
| posted on 16/2/09 at 12:30 PM |
Yes my zx10r clocks when they arrived were at around 6000 rpm,as soon as you connect them they go into a sweep mode up to max rev's,then back
down to zero.
In transit they can move,if you give it a shake you will be able to make it go to a higher reading,but it will not return until power is
connected
wescottishmatt
| posted on 16/2/09 at 12:39 PM |
Tried the shaking thing and yes, now at 8000 rpm.
Happier now (and going considerably faster!!)
| posted on 16/2/09 at 12:43 PM |
If they don't reset when you power the clocks up, just set the tickover at whatever RPM the clocks are stuck on. No-one will ever notice.
Phil
wescottishmatt
| posted on 17/2/09 at 01:18 PM |
Put power up to the clocks last night and they reset back to 0rpm
[Edited on 17/2/09 by wescottishmatt]
