roadrunner
posted on 7/3/09 at 08:29 PM |
Sierra stalk wires
Could some nice chap tell me which of these wires i need for my toggle switches.
I have a three pin switch for indicators ,a three pin switch for the lights and a two pin switch for the dip/main beam,
Thanks Brad.
sierra stalk wiring
mistergrumpy
posted on 7/3/09 at 08:39 PM |
Brad I can't help because I had a nighmare with mine but I did learn that the colours of the wires varied slightly between some years so its
worth noting if you have the corresponding switches and plugs and that the wires in your diagram reflect the wires you have.
roadrunner
posted on 8/3/09 at 09:47 PM |
This is the correct wiring for my stalks, i can figure out some of the wires, but i dont know where to put them all.
omega 24 v6
posted on 8/3/09 at 10:17 PM |
Black/white 49a to the common pin of your indicator toggle switch.
Black/white L to the left side of toggle switch
Black/green r to right side of toggle switch.
That should do your indicators Ok. I presume your leaving the hazard as is??
The lights are a bit more complicated as the stalks switched relays on the sierra. I'd ask if your switches were up to the loads required
first.
You'll still need a relay for the dim dip switch if your using a 2 pin switch for it. ideally you'd need a 3 pin on of switch with a
common/normally closed/normally open setup on the rear
[Edited on 8/3/09 by omega 24 v6]
