Author: Subject: Connecting a wideband controller to 2 things...
supercat
posted on 9/3/09 at 10:27 AM Reply With Quote
Being fairly new to this stuff... can I connect a wideband controller to 2 things - in this case a datalogger and my Emerald ECU? I'm thinking of getting and Innovate LC1.
James
matt_claydon
posted on 9/3/09 at 10:51 AM Reply With Quote
ILC1 has 2 configurable outputs, so you can use one for the ECU and one for the logger.
If both units take the same signal then in theory you should be able to use one output for both (it's just a 0-5v voltage output), but since you have two with the LC-1 you may as well use them.
lsdweb
posted on 9/3/09 at 11:04 AM Reply With Quote
James
What datlogger are you using? Emerald now can talk to data loggers using CANBUS - mine works with my Racetechnology logger / Dash1 nand it makes setting up the logger so easy - everything the ECU can measure can be logged with no extra wiring!! It did take Emerald and Race Technology ages to get it sorted though!
Regards
Wyn
supercat
posted on 9/3/09 at 08:23 PM Reply With Quote
It's an ETB Digidash. I think it is CAN capable but I haven't looked into connecting the two of them up yet.
James
lsdweb
posted on 9/3/09 at 09:02 PM Reply With Quote
James - I'd speak to Karl at Emerald as he's keen to get CANBUS working - it's so much easier to log data - when I had it setup on the last car, the only connections to the data logger were the power supply and the oil pressure and temperature connections. Plus the serial connector from the ECU.
flak monkey
posted on 9/3/09 at 09:07 PM Reply With Quote
Yes you can, just split the output into 2 and connect one to the dash and one to the ecu.
Did it with my LC1 - one output to aim dash and the other to megasquirt ecu.
Simple as that
PS yes the lc1 does have 2 outputs but only one is wideband, the other is simulated narrow band...
[Edited on 9/3/09 by flak monkey]
Sera
http://www.motosera.com
chasmon
posted on 9/3/09 at 10:05 PM Reply With Quote
Not true, LC1 (or at least mine) has 2 user configurable outputs ie both can be 0-5v 10-20 AFR
chasmon
posted on 9/3/09 at 10:06 PM Reply With Quote
in fact....
flak monkey
posted on 9/3/09 at 10:07 PM Reply With Quote
I stand corrected
Must have misread the instructions LOL!
Sera
