flak monkey
| posted on 9/3/09 at 07:41 PM |
Odd indicator/hazard issue
Rewired matts dash at the weekend to do away with the sierra stalks and have a bit of an odd problem.
The indicators themselves work fine with ignition on.
However to get the hazards to work you need to have the indicator switch on (either left or right it doesnt matter). And they work with the ignition
on or off as they should, but you need to have the indicator switch flicked one way or the other.
Got me stumped What have I missed?
Sera
http://www.motosera.com
mr_pr
| posted on 9/3/09 at 07:48 PM |
Any chance of a quick diagram showing how you think you have wired it up?
My Build Progress
omega0684
could it be that you've missed an earth and when you put the indicator on it makes the earth that the hazards need
flak monkey
| posted on 9/3/09 at 07:56 PM |
The only connection on the hazard switch I havent connected is the one for the dash warning light. Tried shorting it to earth and to 12v but neither
worked
Its a VWP rocker type hazard switch by the way.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/switches/rocker.php
I would have to get the diagram from matts for how I wired it up, cant remember off the top of my head...
[Edited on 9/3/09 by flak monkey]
Sera
roadrunner
| posted on 9/3/09 at 09:12 PM |
I have been trying to work all mine out, i thought i would get a toggle on/off switch for the hazards that would have two pins at the back, but it
seems there are three wires for the hazards to work.
Michael
| posted on 9/3/09 at 09:30 PM |
Im only guessing, but if the hazards only work when indicator switch either left turn or right turn then you need to run a feed from the flasher relay
to hazard switch.
matt.c
| posted on 9/3/09 at 09:43 PM |
<-------------------- Dam Wiring!
| posted on 9/3/09 at 09:59 PM |
My hazard switch has 2 power feeds - one's from the switched 12v supply and the other from the unswitched side. There are also about 8 other
wires!
flak monkey
| posted on 9/3/09 at 10:04 PM |
IIRC this switch has 7 connections.
One switched live
One permanent live
One to left indicator
One to right indicator
One to pin 49a on relay
One to another pin on relay
One to dash warning light - which i havent connected to anything...
I will however have to consult the destructions which came with it to double check!
Sera
matt.c
| posted on 12/3/09 at 09:03 PM |
Does this help?
[img][/img]
mr henderson
| posted on 12/3/09 at 09:07 PM |
I used one of the CBS hazard kits recently, has its own relay and is dead simple to use. Too late in this situation I realise, but might help someopne
else who hasn't tackled that part yet.
John
flak monkey
| posted on 12/3/09 at 09:15 PM |
quote: Originally posted by matt.c
Does this help?
Thats the switch I used and wired up following that diagram to a std 3 pin relay.
I will have a play around next time as I think I might know what the problem is, but then my memory is rubbish!
Sera
mr henderson
| posted on 12/3/09 at 09:46 PM |
I'll bet as soon as you draw a diagram of what is actually there you will see what the problem is
John
flak monkey
| posted on 12/3/09 at 10:18 PM |
John
Without a doubt!
Its something pretty simple as everything else seems to work ok!
Sera
