Author: Subject: 11 headlights
I love speed :-P
posted on 15/2/04 at 11:12 AM Reply With Quote
11 headlights
Does any1 have any suggestions on which headlights to use 4 my 11 bodywork, c pic to c the space 4 the lights
Don't Steal
The Government doesn’t like the competition
chrisg
posted on 15/2/04 at 11:27 AM Reply With Quote
They used to use mini ones, either sealed beams or the ones with seperate bulbs.
Have you got perspex covers?
cheers
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
madforfishing
posted on 15/2/04 at 11:28 AM Reply With Quote
By the look of your bodywork (nice by the way) I would say have a look at Jaguar or Porsche. Neither of which are going to be cheap.
It's hard to see from your pic but if the lights recesses are round - try pre '67 beetle?
I am standing by to be shot down if flames.
Que torrent of abuse
Staple balls
posted on 15/2/04 at 11:39 AM Reply With Quote
Is that the GTS bodywork? if so could you get more photos of it? side on and arse end especially
I love speed :-P
posted on 15/2/04 at 11:40 AM Reply With Quote
will do i am picking it up 2morrow
Don't Steal
Staple balls
posted on 15/2/04 at 11:46 AM Reply With Quote
excellent
cheers
Spyderman
posted on 15/2/04 at 12:59 PM Reply With Quote
You can use the bog standard 5 1/2" or 7" lights you get from motor factors.
Measure the flat area to see which will fit best.
What might be a problem is the housing making contact with the tyre when cornering. These often need spacing forward a bit for clearance.
Terry
Spyderman
andyps
posted on 15/2/04 at 10:45 PM Reply With Quote
I'm sure Chris is right - standard 7 inch lamp units from a mini etc.
chrisg
posted on 15/2/04 at 11:19 PM Reply With Quote
Thanks Andy, thought I was going mad!
The Westfield 11 certainly used mini lamps.
They also had perspex covers, as an option.
Chris
Findlay234
posted on 16/2/04 at 09:27 AM Reply With Quote
like this:::: Rescued attachment 0c6423a0.jpg
Steve @ sVc
posted on 16/2/04 at 03:13 PM Reply With Quote
7" lamps were fitted as standard - if you are need ing to see where you are going - fit H4 halogen, not sealed beam.
The original cars had the Lucas 2 adjuster metal backed "Nests" that the lenses fit into. These are still available. Most builders now use the plastic nests - less expensive, lower weight - doesn't rust!
Lotus used Lucas lights - these are still on the market, but be quick, they are out of production. Otherwise us Wipac lenses.
Regards
Steve - sVc
