ditchlewis
| posted on 28/3/09 at 06:53 PM |
wiring the wipers with the vickie green loom
does any one know if the vickie green loom is correct for the wiper circuit? when i start the engine the wipers start. there is no intermitant no fast
and no stop, only on..
i'm running a lucus motor if that helps
should i just get a new switch and make a new sub loom for the wipers?
ditch
| posted on 28/3/09 at 06:54 PM |
Doesn't sound right!!! Have you got a intermitent relay for the intermitent wiper function?
ditchlewis
| posted on 28/3/09 at 06:57 PM |
I've put the loom and the relays supplied in as the loom diagramme, which has proved wrong before.
looks like i will ba making a small loom just for the wipers then.
ditch
gregs
| posted on 28/3/09 at 07:01 PM |
I've got mine working on the VG loom, with an audi intermittent relay, MGB wipers and sierra switch gear.
From you description is sounds like the park switch ain't cutting in....there is a continuous feed to the motor to park the wipers, if the
switch isn't breaking the circuit then they carry on trying to park. HTH
adithorp
| posted on 28/3/09 at 07:07 PM |
There's a wiring diagram for the Lucas wipers on the SVC web site. Really needs the lucas wiper switch to make it work but can be done without
but it's tricky.
adrian
http://jpsc.org.uk/forum/
ditchlewis
| posted on 28/3/09 at 07:40 PM |
looks like the Vicky green loom is ment for the robin hood with the ford wiper motor. i will create a new sub loom i think.
ditch
ditchlewis
ditch
ditchlewis
ditch
| posted on 28/3/09 at 11:19 PM |
You can say that again
Dusty
| posted on 29/3/09 at 04:12 AM |
The sierra wiper motor runs off the same five wires as the lucas wiper, same wire functions and the column switch does the same things. Just not the
same colours. Unfortunately I don't have the VG colours to tie in to the pic.
| posted on 29/3/09 at 11:33 AM |
Have a look on the Robin Hood owners site, there is a wiring diagram , worked for me. Must work out how to put in link .
