Author: Subject: Amp Gauge wiring
madrallysport
posted on 13/4/09 at 10:57 AM Reply With Quote
Amp Gauge wiring
Sorry for such a dumb question, but how to wire an amp gauge in, i can't get mine to work.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
posted on 13/4/09 at 11:04 AM Reply With Quote
It's wire in serial. IE split the wire you want to measure the amps in, put on connector to one terminal, one to the other. Job done!
Mr Whippy
posted on 13/4/09 at 11:10 AM Reply With Quote
nitram38
posted on 13/4/09 at 11:18 AM Reply With Quote
I think you mean series......
What it means is you go throught the ammeter with the circuit and through the load to complete it.
posted on 13/4/09 at 11:39 AM Reply With Quote
I do indeed. Always though serial and parallel made more sense though (that's my excuse anyway and I'm sticking to it!!)
posted on 13/4/09 at 01:30 PM Reply With Quote
Really best to try and avoid fitting an ammeter, these days with alternators doing the charging a voltmeter/batter condition gauge is the way to go.
posted on 14/4/09 at 08:21 AM Reply With Quote
I am with BT - don't bother.
the ameter will take quite large currents and ideally you do not want to introduce addtional circuitry or long wires in the charging cicuit.
a voltmeter will tell you if you alternator is charging; in fact the charge lemp will as well but on a much lower resolution.
[Edited on 14/4/09 by 02GF74]
