Author: Subject: Anyone used a Lotus dash?
posted on 22/4/09 at 07:42 PM Reply With Quote
As above really, Stack dash out of an Elise or Exige???
Anyone got one spare?
Hammerhead
posted on 22/4/09 at 07:53 PM Reply With Quote
not going spare, but I am using one. only cost £55. I am using an elise loom aswell so most of the system plugs together.
rayward
posted on 22/4/09 at 08:27 PM Reply With Quote
looked at it before, if you get the one from the k series engined car its pretty easy to wire in, on the later/toyota engined ones i couldn;t get the speedo to work
might have a wiring diagram somewhere if you need one
Ray
posted on 22/4/09 at 08:51 PM Reply With Quote
Just toying with ideas atm. My Acewell doesn't look very trick to me anymore, already fitted a 52mm fuel gauge and temp gauge will be next.
Wiring diagram would help as would the plug that goes in the back with a bit of wire, or a loom..
The car I was looking in had a K series and went to 8K and 140mph, looked really good imo, unlike the rest of the inside
Ta,
Miks15
posted on 22/4/09 at 09:16 PM Reply With Quote
If its all there!
tegwin
posted on 22/4/09 at 09:58 PM Reply With Quote
Im sure I remeber this being disucssed in the past....
There was a company who made an adapter that plugged into the back of the later Elise dash modules and allowed you to plug in "generic" sensors etc for speed, pressure, temp etc....
www.verticalhorizonsmedia.tv
loggyboy
posted on 22/4/09 at 10:02 PM Reply With Quote
I have one in the Nova, well a vx220. very easy to wire in, elec speedo signal comes from astra digidash transducer, is calibrated by a pulse converter (Made by a guy on migweb.co.uk). pretty much every thing else is plug n play bar the fuel gauge which currently works the wrong way round!
pics may not work as host is messing me around!
Video
http://www.youtube.com/watch?v=aVxYAAsmsfU
Mistral Motorsport
cd.thomson
posted on 23/4/09 at 07:27 AM Reply With Quote
A fellow dax builder has one in his vauxhall engined rush. I think everything hooks up easily but the speedo, which hes using a converted ABS sensor to run.
Craig
loggyboy
posted on 23/4/09 at 10:48 AM Reply With Quote
Im pretty sure the elise uses an ABS sensor for the speedo signal as standard.
Mistral Motorsport
