Author: Subject: Tintop Audi oil light
JonBowden
posted on 25/4/09 at 04:50 PM Reply With Quote
I have an old 2l Audi A6 (1995, like the audi 100)
A few days ago, the dasboard "computer" started displaying the low oil pressure warning symbol after about 10 mins of running.
To see if there was oil being pumped, I removed the sensor - loads of oil went everywhere. I also used a multimeter to verify that the pressure sensor switch (just sbove the oil filter) closed just after the angine started.
This leads me to believe that the problem is in the dasboard instrument module - I have heard that this is a common problem. Any idea how I can fix this or at least stop the oil warning symbol?
Jon
tomgregory2000
posted on 25/4/09 at 05:11 PM Reply With Quote
Stick some tape over it, problem solved
posted on 25/4/09 at 05:17 PM Reply With Quote
Do an oil pressure test to start with, if OK then try a new switch .
JonBowden
posted on 25/4/09 at 06:57 PM Reply With Quote
I have tested the switch with a multimeter - it switches on just after the engine starts presumably due to oil pressure.
Jon
mark chandler
posted on 25/4/09 at 07:08 PM Reply With Quote
Earth the oil pressure switch wire and go for a drive, if it does not illuminate then its telling the truth !
JonBowden
posted on 26/4/09 at 12:13 PM Reply With Quote
I'll try that
Jon
