Author: Subject: Hazard and Indicator problem Still
Kitlooney1000
posted on 25/2/04 at 08:49 PM Reply With Quote
Although the car is 95% complete, I am still having problems with hazards and indicators. the problem is when you press the hazard switch ( from an astra, 7 spade connections) all the indicator lights come on but dont flash, if you take out the relay, they still come on. when you indicate left or right , they dont flash with or with out the relay. this is driving me spare. any ideas would be grateful .... please..
flak monkey
posted on 25/2/04 at 09:01 PM Reply With Quote
See the thread under this one for a simplified diagram of the hazard circuit. Though you have probably already seen it!
Just checking
Sera
http://www.motosera.com
Kitlooney1000
posted on 25/2/04 at 09:35 PM Reply With Quote
sorry cant find the diagram
flak monkey
posted on 25/2/04 at 09:45 PM Reply With Quote
This is the diagram i was on about. Though its probably not what you were after! was worth a try i spose
from here
http://www.locostbuilders.co.uk/viewthread.php?tid=11092
[Edited on 25/2/04 by flak monkey] Rescued attachment scan0002.jpg
Sera
the problem is mixing and matching different components. i would reccomend going back to basics - find out how hazards work in general, find out a good aftermarket way of doing it (on a kit car wiring type of site - ask if you want a link!), find out how the astra switch works in an astra, and then work out a solution. Will make you feel much better!
it does sound quite complex having a 7 spade switch, does this do the indicators as well as the hazard? is the relay built in too?
wouldn't it be great if someone made a little black box that just does everything!
Staple balls
it's about 1/2 way down http://www.locostbuilders.co.uk/viewthread.php?tid=11092
Kitlooney1000
posted on 25/2/04 at 09:51 PM Reply With Quote
Thanks guys, may have to rethink the switch, too many connectors
A Badger
posted on 25/2/04 at 10:45 PM Reply With Quote
Seven connectors sounds about right. Look at the top disgram the switch has 9 connections. If you do have a specific warning light for the hazards, but use the existing indicator lights you would only need 7 connectors.
Andrew
A Badger
posted on 25/2/04 at 10:47 PM Reply With Quote
It's just hit me--- where have you placed the relay? Look at the diagram the relay comes before the switch rather than after.
Andrew
Kitlooney1000
posted on 26/2/04 at 09:14 PM Reply With Quote
I think i have figured it out, i seem to have bypassed the relay some how, the power is going straight to the switch, not the relay. also i have an electronic relay in there not a bi-metallic one, well thats what i think is wrong, let me know if you know otherwise.
