Author: Subject: Which solenoid should I get?
james h
posted on 16/5/09 at 03:52 PM Reply With Quote
My starter solenoid seems to have given up the ghost - everytime I try to switch the engine on it just buzzes like mad - I have checked all the connections on the battery, topped it up and charged it to da max, but still no change.
So, which starter solenoid would you recommend for a 2000 R1?
Thanks,
James
MakeEverything
posted on 16/5/09 at 04:19 PM Reply With Quote
Sounds like a siezed starter?
Kindest Regards,
Richard.
sprouts-car
posted on 16/5/09 at 06:17 PM Reply With Quote
I had a similar problem, completely different engine though.
Found it was just a bad earth in the end.
No idea why it made it buzz but it did. Just an idea....
Chris
james h
posted on 16/5/09 at 06:26 PM Reply With Quote
Hmm thing is the car was firing up fine before I took the battery off one night to charge it - I don't remember changing any electrics or anything
posted on 16/5/09 at 09:17 PM Reply With Quote
Yup. Could be a poor earth preventing the solenoid from closing properly....
MautoK
posted on 17/5/09 at 06:54 PM Reply With Quote
What about the earth connection on the engine?
Over the years I've had failures due to
  • Oxidation of battery posts
  • Failure of the clamp connector (corrosion)
  • Bad earth to body/engine
  • Sudden battery death
and in all cases they were sudden onset - all normal until it wouldn't start.
[Edited on 17/5/09 by MautoK]
james h
posted on 17/5/09 at 08:18 PM Reply With Quote
Well I think I have sorted the problem - I got the old jump leads out and managed to get it started. I rubbed the battery posts down with glass paper to get a better connection so I think the battery is very weak.
Thanks,
James
