speedyxjs
| posted on 16/5/09 at 06:23 PM |
DIY Engine wiring
I have to chuck the wires that came with my engine as they were shot and now that i cant find any on fleabay, im thinking i might make my own, being
locost and all that.
What i need to know is where i can get the different coloured wires and the plugs from (for fuel injectors etc)?
Also would it be possible to use a 4.0 ECU if i worked out what pins do what as i cant find a 3.6 ECU anywhere?
clairetoo
| posted on 16/5/09 at 06:25 PM |
VWP are pretty good .................
Its cuz I is blond , innit
Claire xx
Will weld for food......
NeilP
| posted on 16/5/09 at 06:26 PM |
Vehicle Wiring Products will do the cable and most connectors - If you can't source a jag ecu then the next cheapest would be megasquirt
- The MegaEFI boys will do one with most of the wiring for just over £200 IIRC...
HTH
EDIT: Thems wot Claire sed
[Edited on 16/5/2009 by NeilP]
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
speedyxjs
| posted on 16/5/09 at 06:29 PM |
I will go megasquirt eventually, i just dont have the money atm and i really want to start the engine in the next few weeks.
speedyxjs
| posted on 16/5/09 at 06:36 PM |
The plpug i need is one that fits on here:
I can get a 3.2 or 4.0 ECU for around £20. Im just not sure if i will have any problems with a 3.6 engine.
clairetoo
| posted on 16/5/09 at 06:54 PM |
These are what you need for injectors
Claire xx
mark chandler
| posted on 16/5/09 at 07:09 PM |
You may struggle, having the brain is only part of what is required.
You will also need the ballast resistor block, air flow meter and other bits and bobs. The 4.0l ECU also ran the sparks via the distributor, the 3.6
just ran the EFI element.
Better to save for megasquirt IMHO.
Regards Mark
speedyxjs
| posted on 16/5/09 at 08:03 PM |
Thanks guys (and Claire ). Megasquirt it is then.
Volvorsport
| posted on 17/5/09 at 08:04 AM |
injector plugs and other fittings are junior timing housing plugs - you can swipe most of that from a scrap car .
most cars have got those nowadays .
www.dbsmotorsport.co.uk
getting dirty under a bus
