Author: Subject: HT Leads
phoenix70
posted on 21/5/09 at 11:22 AM Reply With Quote
HT Leads
Hi All,
Just trying to sort out a new set of leads for my cars, as I'm using a Pinto engine with a coil pack (Hook type Ford one) rather than a distributor so I can't get a standard set. Is the best option to get a set made up, or can I buy single leads that are the right length with the right end somewhere.
Any help appreciated.
Scott
cd.thomson
posted on 21/5/09 at 12:29 PM Reply With Quote
also interested in this. Where would one get their grubby mitts on HT leads that can connect a EDIS based coil to my c20xe plugs?
Craig
omega0684
posted on 21/5/09 at 01:03 PM Reply With Quote
magnecor will custom make leads for you, might be worth an e-mail
dhutch
posted on 21/5/09 at 01:47 PM Reply With Quote
There was a deal on through WSCC for around 25% off leads from theses people.
http://www.performanceleads.co.uk
Dont know if its still on, perksy was dealing with it.
Daniel
MkIndy7
posted on 21/5/09 at 01:53 PM Reply With Quote
The standard Fiesta leads fit fine, pretty sure thats what i've bought the last twice for:
Coil pack - Pinto
Coil pack - Triumph Spitfire
phoenix70
posted on 21/5/09 at 06:28 PM Reply With Quote
Coil pack - Pinto
What year and model of Fiesta?
I looked at some for a Fiesta and they had the long sparkplug end for a 16v engine.
Hopefully a standard set will work as it will be a lot cheaper that a custom set.
Out of Interest where did you mount the coil pack, I've mounted mine at the back of the engine on the scuttle.
Ta
Scott
MkIndy7
posted on 21/5/09 at 10:13 PM Reply With Quote
We've mounted the coil on a bracket which is held on by the two top most engine to bell housing bolts.
I'm pretty sure there the same leads as a
M Reg 1.1 Fiesta Sapphire I had once if thats a bit more specific.
You know what the coil pack end looks like so you could always take a Pinto plug with you to try in the other end.
I wonder if a later Redtop coil pack could be fired by the EDIS unit if its the correct resistance or whatever the criteria for the EDIS to run properly is, its only 2 wires to connect up, Then you could use standard (late XE) leads.. but even standard ones are pretty expencive!.
