Stuart_B
| posted on 28/5/09 at 05:01 PM |
speedo sensor
hi all, after looking for more places to mount 4 magents and a sensor, i have through what about the cv cover, it is metal and round, but then
throught if i place the sender on side on to the round tube and place mangets on the cover, would it read ok?
thanks
stuart
austin man
| posted on 28/5/09 at 08:05 PM |
stick the magnets to the cv joint (diff end)with epoxy resin and fabricate a bracket to mount the sensor too. can also mount on a wheel problem is if
you need to change the wheel. Can also be mounted on the prop
Stuart_B
| posted on 28/5/09 at 08:09 PM |
thanks, i will have to start work on the bracket.
cheers
stuart
mad-butcher
| posted on 29/5/09 at 08:24 PM |
rear upright on indy more rigid
Stuart_B
| posted on 30/5/09 at 05:47 PM |
hi, what have you stuck the magents on with?
