Author: Subject: speedo magents
Stuart_B
posted on 2/6/09 at 03:22 PM Reply With Quote
speedo magents
hi all, what glue do you stick on magents to metal?
and the magents does not fall off.
thanks
stuart
Flamez
posted on 2/6/09 at 03:26 PM Reply With Quote
2 part epoxy, put a dab on first and then encapsulate [cover] the magnet
my build mac1motorsports
twybrow
posted on 2/6/09 at 03:29 PM Reply With Quote
I used the epoxy metal stuff, with a wrap of duck tape over the top.
I mixed up two small balls, pushed them onto the prop, then pushed the magnets into the balls and smoothed the epoxy around the magnets.
richardh
posted on 2/6/09 at 03:42 PM Reply With Quote
i drilled a small hole the same diameter as the magnet and glued it into that leaving the magnet about half thickness proud
Time for a change!
posted on 2/6/09 at 06:00 PM Reply With Quote
You drilled the propshaft??????
flak monkey
posted on 2/6/09 at 06:13 PM Reply With Quote
I stuck mine on with PU, 5000miles later its still there
Sera
http://www.motosera.com
Stuart_B
posted on 2/6/09 at 06:16 PM Reply With Quote
right, then well i got ardiet metal 2part expoxy, i hope that will do.
i will clean the cv up, and make a nice bracket for the sensor to beheld in place with.
thanks
stuart
DarrenW
posted on 4/6/09 at 03:02 PM Reply With Quote
Shallow hole in prop adaptor will be fine rather than prop tube itself.
