Author: Subject: Starter motor relay?
speedyxjs
posted on 4/6/09 at 06:13 AM Reply With Quote
How do i know if i need a relay to switch my starter motor or if it is built in?
The SM has two connections on the back, one for +ve battery and one other.
Edit to change solenoid to relay
[Edited on 4-6-09 by speedyxjs]
tilly819
posted on 4/6/09 at 06:38 AM Reply With Quote
it should have a main body and a side bit on the side bit is the sollinoid it will have 2 conections on it one big one for 12V dc straight from the battery and one for the coil of the solinoid the 0v is a frame ground
hope this helps
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
speedyxjs
posted on 4/6/09 at 06:54 AM Reply With Quote
Sorry, its early in the morning. I meant Relay
tilly819
posted on 4/6/09 at 08:18 AM Reply With Quote
workshop manual for the engine???
I would have thought that a relay is not required most starters have a relay in the soilinoid but putting one in would not hurt just run a wire to the positve of the battery to one side of the normaly open and the other side to the coil of the starter moter solinoid then run the a1/a2 coil pair for the relay to a starter switch
But id be fairly confident that it is not nessary might be worth phoning a starter moter specialist up and giving them the part number of the moter and play dumm
Tilly
