Author: Subject: R1 Engine Management light
Pdlewis
posted on 8/6/09 at 10:07 AM Reply With Quote
Im having issues with the engine management light on my R1 5pw (03) it keeps comming on for no apparent reason I, the engine doesnt miss behave when it happens it doesnt throw any fault code on the screen and i cant make it happen on demand any ideas
(I have checked for loose connections everywhere but cant find any)
[Edited on 8/6/09 by Pdlewis]
Build Photo Album
Updated 05/02/2009
afj
posted on 8/6/09 at 11:00 AM Reply With Quote
mine did the same but a could get it to come on if i had some wheel spin?? found a broken wire from the air box temp sensor fixed it and its been fine since yeah i know it dont make sence
eerrrrrrrrrrrrrrrr
adithorp
posted on 8/6/09 at 11:04 AM Reply With Quote
Is it with the car running but stationary for a while? Mine puts it on under those conditions. ECU thinks the speed sensor has failed.
The fault code is only displayed after you stop the engine (with the kill/stop switch) and not while running.
adrian
http://jpsc.org.uk/forum/
Pdlewis
posted on 8/6/09 at 11:57 AM Reply With Quote
Mine does it while it is running!
adithorp - I dont use the Kill/Stop which would explane the lack of code looks like Im wiring that back in at the weekend
Build Photo Album
Updated 05/02/2009
cerbera
posted on 18/6/12 at 08:23 AM Reply With Quote
Resurecting an old thread but, I experianced the engine warning light coming on whilst driving yesterday and it stayed on for a few miles (2-3 miles) before going out again. Whilst it was on there seemed to be no noticable difference to how it was running. When I switched the car off I didn't notice any fault code.
Would you still get the fault code if the engine management light was off when you switch off?
What is this kill/stop switch you mention and how does it differ from just switching off?
