Author: Subject: Ignition barrel key code question
m8kwr
posted on 10/6/09 at 11:18 AM Reply With Quote
I am building a single seater, and planning on using a fiat cinq steering rack.
I wanted to use the steering column and other bits from the cinq - but i do not like the stalks, so want to bits from a fiat seicento instead - i think it has better ones....
If the key for the steering column is coded, am i still able to use it, without using the ecu etc.
Or am i best looking for a different alternative.
theconrodkid
posted on 10/6/09 at 11:22 AM Reply With Quote
the coding relates to the ecu only,if your not using that then no worries
who cares who wins
pass the pork pies
adithorp
posted on 10/6/09 at 12:09 PM Reply With Quote
As said ^^^
The chip/code reading is usually done via a ring fitted around the barrel and separate from the ignition lock/switch.
adrian
http://jpsc.org.uk/forum/
m8kwr
posted on 10/6/09 at 12:51 PM Reply With Quote
many thanks for this, i will go ahead and source some bits for my build..
