GBaggott
| posted on 22/6/09 at 12:29 PM |
Rev counter wire on the ZX14 loom? anybody know the correct colour. Thanks
Im running a ZX14 in an MNR with a digi dash mk2.
I was just wondering if anybody knew the correct wire from the loom that i could connect to the digi dash to get the rev counter working?
I could try the wires one by one but hopefully this post might shorten my time spent in the garage.
Thanks in advance Gareth.
minitici
| posted on 22/6/09 at 04:31 PM |
There is no rev counter wire on a ZX14 - it has a CANBUS system.
However if you have a PowerCommander fitted I'm sure there must be a suitable output from that.
We used a PowerCommander LCD unit as a revcounter on our ZX14 Radical.
[Edited on 22/6/09 by minitici]
skippad
| posted on 22/6/09 at 11:13 PM |
I had the same problem with mine using digidash.
Tried loads of (what i thought was a feed signal wire) paths, until i found i could get a correct signal by splicing into one side of a coil wire. Any
coil will do, experiment with different wires until you pick up correct signal.
