Author: Subject: 99 R1 RPM sensor and speedo sensor feeds
leemarkadams
posted on 26/6/09 at 08:57 PM Reply With Quote
Hello all,
Have tried wiring in mt gear indicator for my R1 engined MK Indy but not sure I have tapped into the right wires for the spped and the RPM, so where do these originate from so I can tap into them there?
Lee
james h
posted on 26/6/09 at 09:23 PM Reply With Quote
Speed is taken from the gearbox - there are 3 wires coming from the sensor.
If you have a speedohealer then you should be able to find it by tracing the wires back to the engine. I am not in the garage now, but if I remember correctly it is mid way between the prop adaptor and the clutch cover, and towards the bottom of the gearbox.
Can't remember where the revs are taken from.
James
leemarkadams
posted on 28/6/09 at 08:30 PM Reply With Quote
Anyone else able to help, as can't seem to get the gear indicator to work....
Lee
mad-butcher
posted on 29/6/09 at 07:45 AM Reply With Quote
rev counter = yellow/black goes from ignitor unit to rev counter (std clocks)
as already said speedo is the triangular plug between gearbox output and clutch cover
(1)white, (2)blue/yellow, (3)black/blue into loom
(1)pink, (2)orange/red, (3)black/white out of gearbox
tony
