RK
| posted on 28/6/09 at 12:38 AM |
Brake light wiring
All the diagrams make it look easy. Not so. This is because I don't know how to isolate the rear lights, without activating all the other lights
when the switch is on.
You want all of them on for indicators and hazards, but only the rear ones for brakes.
PS A follow up to previous rantings about hazards and indicators. I got the indicators working. The hazards would only work, though, with TWO
relays, one for each side. Otherwise, the indicators would activate both sides. I have a two position switch, with 3 pins (one of which is earth). Now
I still have to figure out how to get my dash LED to flash while turning right! Works fine going the other way.
[Edited on 28/6/09 by RK]
YQUSTA
| posted on 28/6/09 at 01:30 AM |
A diagram of what you want to do may help i dont really understand the question either.
Are you on about the brakes or indicator/hazard.
the indicators and hazard can be solved easy enough from other posts and i can whip up a diagram for you if you provide what switches lights and
warning lamps you have on a simple diagram.
linky to a diagram for indicator/hazard
read to the bottom for the correct config.
YQUSTA
RK
| posted on 28/6/09 at 01:39 AM |
My hazard switch has two pins, not three.
RK
| posted on 28/6/09 at 01:43 AM |
OK, I want brake lights to illuminate the back lights. I want hazards to operate all the lights, and I want the indicators to indicate left and right.
I have the last two parts figured out, but not the first.
Sorry if it doesn't make any sense. The more I try to draw things out, and wire them on the car, the less sense it makes to me. It would be nice
to just wire up a Sierra switch or use those fancy push buttons but we don't have those here and I have to improvise.
RK
| posted on 28/6/09 at 02:44 AM |
pic not including dash indicator/hazard light.
As you can see, with my way, there is no way to get the wire to the rear lights and not the others at the same time.
RK
| posted on 28/6/09 at 02:45 AM |
pic
Macbeast
| posted on 28/6/09 at 05:08 AM |
Surely tail, brake and turn lights should be separate lights? There should be separate wiring for each function.
rgrs
| posted on 28/6/09 at 08:55 AM |
As the OP's based in canada, are you using the brake lights as turn signals as well ?
if so see linky
Roger
[Edited on 28/6/09 by rgrs]
YQUSTA
| posted on 28/6/09 at 09:19 AM |
  wiring help
I have modded the diagram to show where you would need to add the wiring and insert some diodes to stop any feed back.
I'm not sure if this is what you are exactly after though but it would make the rear lights work as brakes and flasher unit.
also note that i removed the feed from the front side lights to the rears and replaced them to come straight from the relays.
With diodes all you have to remember is that the band must face the direction that you want to stop feed back from happening.
Hope this helps.
YQUSTA
RK
| posted on 28/6/09 at 11:57 AM |
I am using one light on each side, with two inputs on each.
Brake/Turn and Tail.
Where in the circuit would that suggested relay go? And why didn't I get to see all these builders in Kent while I was there??? I didn't
meet anybody at Detling.
Macbeast
| posted on 28/6/09 at 12:47 PM |
Didn't know you were there eh :-)
YQUSTA
| posted on 28/6/09 at 05:46 PM |
I did not suggest putting a relay in.
i assumed the links between the front and rear lights were for the flashing of the hazards/turn.
if you are using 1 feed for turn/brake then just put the green wires on the same connection as the black and red ones. that will get you working for
braking and turning/hazard.
if you are having the front lights flash when the hazards are on do you need the tail lights to flash also? or just the turn/brake light?
also how many feeds can the front lights take if they are to flash? is there just 1 or more?.
RK
| posted on 29/6/09 at 02:15 AM |
I ran all the lights on one side together to run the indicator for that side. If I run the Brake light wire to that side, obviously all the lights go
on, not just the back ones.
I am not about to wire diodes all over the place. I am not that capable.
But thank you very much for the suggestion! I am sure I need another hazard switch like everyone else seems to use. That way everything wires into it
and nothing crosses or feeds back.
RK
| posted on 29/6/09 at 10:00 PM |
It was easier and cheaper to get diodes than a hazard switch, so I have 8 of them. I'll let you know how it works!
Merci again everyone.
RK
| posted on 30/6/09 at 12:27 PM |
As much as I hate to admit victory, it worked!
