Author: Subject: Savage Switch Connection - Pt2.
Dick Axtell
posted on 11/7/09 at 04:53 PM Reply With Quote
OK Guys (or even Ladies?) - We now know that Savage switches all have the same wiring/connection diagram, thanks to this recent thread :-
http://www.locostbuilders.co.uk/viewthread.php?tid=116847
My question now is - what is meant by the word "source"? Terminal 1 is connected to +12v supply; terminal B is earthed (-ve); terminal 2 to "source"(?); and terminal A to illumination supply.
Do I assume that "source" means the device to be controlled by the switch?
I'd be very grateful for some clarification.
Flamez
posted on 11/7/09 at 05:02 PM Reply With Quote
yep you're right. Think of it as 1= power in 2=power out [doesn't matter which bank or side you use]
a = b illumination
my build mac1motorsports
sorens2
posted on 11/7/09 at 05:21 PM Reply With Quote
And how do I takt them off my dashboard ?
When I loosen the nut it just comes loose but the square can´t get through the hole ????
Soren S2
Flamez
posted on 11/7/09 at 05:40 PM Reply With Quote
Easy, the connector block clicks off, I think there is a catch on one side. Then you are left with the barrel of the body. Unscrew the aluminium collar and all becomes apparent.
Dick Axtell
posted on 11/7/09 at 09:04 PM Reply With Quote
a = b illumination
Many thanks for the confirmation.
