Major Stare
posted on 12/7/09 at 08:50 AM |
Digidash lite... do i use supplied fuel sender?
R1 is fitted and using existing Smiths fuel sender unit.
Its not reading correctly.
Do i fit ETB's DigiDash fuel sender, is it a straight swap?
Jon "FISH"
Gazeddy
| posted on 12/7/09 at 09:11 AM |
i would. makes sense to make it read correctly its calibrated for use with the gauges im going to be using all the sensors from etb
maximill666
| posted on 12/7/09 at 09:28 AM |
Have you tried altering the fuel sender settings on the digidash?
goaty
| posted on 12/7/09 at 09:33 AM |
go on there website and look at the PDF file, it states whatones can be used if you want to try to keep your current one.
Major Stare
| posted on 12/7/09 at 11:38 AM |
No... will have a look after the GrandPrix.
Cant fit the Digidash sender as i need to drill the tank to accept fixing.
Had a look at existing sender, the fuel tank is 1/2 full, so i have adjusted the existing sender to read correctly.
Will update after GP
Jon "FISH"
