hissingsid
| posted on 4/8/09 at 06:39 PM |
Tube Fuel Sender
Not sure if this is in the right section.
Does anyone know where you can buy one of the above? Needs tobe a tube sunder as it will be going in a foam filled tank.
I've found some on the net and on marine suppliers but was wondering if anyone has found a very fair priced item?
Ebay can be a bit hit and miss for these.
Graham
GeorgeM
| posted on 4/8/09 at 06:42 PM |
got mine at ETB Instruments, Southend
HTH
GeorgeM
hissingsid
| posted on 4/8/09 at 06:52 PM |
How much did it cost you George if you don't mind me asking?
miikae
| posted on 4/8/09 at 07:23 PM |
How long must it be as a Porsche 924/944 tube sensor is approx 215mm long , there are a couple on ebay at the moe.
Mike
If it can be done it i will be done .
GeorgeM
| posted on 4/8/09 at 07:31 PM |
got mine as an upgrade with the digidash (they make them) so not sure.
Give them a ring on 01702 601055, they supply different lengths too.
I've been there a few times, & are always very helpful
GeorgeM
Volvorsport
| posted on 4/8/09 at 08:13 PM |
the vdo ones re £55 , theres some avaition ones you can get which you can adjust to your fuel gauge .
and thats the point , you need the correct resistance and from high to low or vice versa , so you should really buy both together .
have a look on some DIY aeroplane sites , cant remember where ive seen it , but the sender can be matched to most anything .
www.dbsmotorsport.co.uk
getting dirty under a bus
hissingsid
| posted on 5/8/09 at 06:22 PM |
Cheers for the replies guys.
I'm aware of the voltage for the gauge.
I'll have another look about then.
Graham
