Xtreme Kermit
| posted on 15/8/09 at 08:21 PM |
Locost turn signal buzzer
Fed up with leaving the indicators on and not spotting the flashing light?
Well I fitted a locost buzzer during the week.
I used one maplin 12v buzzer, two diodes capable of taking the buzzer current (100ma), soldering iron, piggy back spades, some heatshrink and servo
tape.
Connected the negative on the buzzer to earth, the positive to the ends of both diodes with solder blob. Fit heatshrink over bare wires. Fit piggy
back spades to the other ends of the diodes and use more heatshrink to cover the bare wires.
Use the piggy back spades to tap into both wires on the back of the indicator warning light. Servo tape the buzzer to the back of the dash.
Voila - one cheap indicator warning buzzer that can be heard up to about 60mph.
Here is the buzzer I used
http://www.maplin.co.uk/Module.aspx?ModuleNo=3213
RichardK
| posted on 15/8/09 at 08:26 PM |
Nice one matey, don't suppose you have the maplin codes of the diodes as well do you, just so I get the right stuff.
Rich
Gallery updated 11/01/2011
RichardK
| posted on 15/8/09 at 08:28 PM |
Just out of curiosity, why couldn't the black gone to earth and the red go to the dash indicator bulb?
Rich
MautoK
| posted on 15/8/09 at 08:38 PM |
Rich
Generally the W/L is wired between the NS circuit and the OS circuit. The W/L bulb grounds through the non-active indicator bulbs; it's not
directly grounded.
John.
blakep82
| posted on 15/8/09 at 08:46 PM |
for £2 each, i guess it wouldn't break the bank to just fit one for each side. saves worrwing about diodes and stuff
________________________
prawnabie
| posted on 15/8/09 at 08:50 PM |
Blake, will that not put more load on the circuit, making the flash slower?
iscmatt
| posted on 15/8/09 at 09:40 PM |
for a buzzer i just bought a flasher relay with a buzzer off ebay for cheap, works a treat
| posted on 15/8/09 at 09:41 PM |
Originally I had a buzzer, 'cos I kept leaving my indicator on. After a while it drove me nuts and really got on my nerves.
It was replaced by a Bright-6 light unit and a proper self-cancelling unit for my Sierra steering column.
blakep82
| posted on 15/8/09 at 10:45 PM |
only one way to find out
nah, i don't think it would though, because the way he's done it, you turn left and the indicators have a buzzer in the circuit, you turn
right and theres a buzzer in that circuit.
having one on each won't have any other effect on it. and i think flasher relays only change speed when they get below a certain load. i
don't think adding more will make it flash slower
| posted on 16/8/09 at 09:22 AM |
re: 2 buzzers - chance are they are not madeto precise tolerance so would have different tones so you would know which side is indicating.
re: flash rate, maplins say 100 mA but I reckon it would be less; compare that to two filament bulbs, 21 W each or 4 A total so approx 2 % difference
- nothing to worry about.
prawnabie
| posted on 16/8/09 at 09:26 AM |
Ahh my bad, not being picky blake! Its just that its exactly what I would do and it usually goes wrong lol
Shaun
