55ant
| posted on 17/8/09 at 10:07 AM |
electrical issue with headlight/indicator
really need some help guys
right, on my indy the passenger headlight is very dull when on, also when on normal beam the indicators light up (constant and dull), when on full
beam the passenger headlight goes of completely. also when main lights are on the left indicators flash really quickly so resistance is out?
any ideas guys?
Guinness
| posted on 17/8/09 at 10:12 AM |
Sounds like the headlight is earthing through the indicator circuit, or the other way round.
I'd be taking the front and back lights apart, and checking the wiring.
Mike
omega 24 v6
| posted on 17/8/09 at 11:19 AM |
Bad earth methinks as well.
Dangle_kt
| posted on 17/8/09 at 11:24 AM |
I had a very interesting fault on mine where the sidelights would come on whenever the brakes were applied - much to the amusement of the SVA testers
at Chadderton!
Can I suggest you start simple? After weeks of messing and issues mine turned out to be a faulty bulb - maybe check bulbs, then rear lights, then
front lights, then junctions where the loom meets - maybe an insultator has come off a connector?
55ant
| posted on 17/8/09 at 11:46 AM |
cheers guys, i will be looking over it tommorow! wish me luck
greglogan
| posted on 17/8/09 at 12:26 PM |
Check the voltage of the bulbs also - just to make sure they're 12V !
Women are meant to be loved, not understood.
