FrankP
| posted on 30/8/09 at 04:24 PM |
Brake Fluid Warning Light
If I undseratnd the rules the brake fluid has to have a warning light - on that can be tested to how the light is working?
Does it have to light up when you turn the ignition on or can it be on a tester switch.
Any suggestions or advice gratefully recieved.
Frank
| posted on 30/8/09 at 04:27 PM |
You can double it up with the handbrake warning light so it serves both functions or have it on a switch which doesn't latch. It doesn't
need to come on with the ignition like ABS light.
Flamez
| posted on 30/8/09 at 05:53 PM |
You don't require a handbrake light but do require a test function. Many use a convoluted switch on the handbrake for this purpose. I used a
simple switch on the dash for sva [along with the test button on the reservoir] and passed no probs.
my build mac1motorsports
Nash
| posted on 30/8/09 at 06:47 PM |
Mine is linked to the handbrake switch light. If you remove the top from the Brake resovior the light illuminatesala loss of brake fluid. I
don't have a switch in the circuit.
.....Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
blakep82
| posted on 30/8/09 at 07:14 PM |
.....Neil
the handbrake counts as the switch you 'don't have'
but yeah, either wire it through the handbrake switch or put a push switch on the dash
________________________
