A Badger
| posted on 25/3/04 at 06:10 PM |
rev Counter Take off
I've got a 79 pinto anybody know the place to connect a rev counter?
thanks
Andrew
| posted on 25/3/04 at 06:34 PM |
negative terminal of coil is usual place. Rusty
| posted on 25/3/04 at 07:16 PM |
If you have the wiring from the car there is a light green wire there which is used for the job.
dblissett
| posted on 25/3/04 at 07:50 PM |
inductive
hope this helps
dave blissett
A Badger
| posted on 25/3/04 at 10:45 PM |
Thanks for the diagram, I figured it wasn't too difficult. Interestingly my pre 85 pinto does not seem to run the amp unit. Just a black wire
from the coil to the side of the distributor (Condenser?)
greggors84
| posted on 29/3/04 at 12:56 AM |
My ignition doesnt have an amp either, just a black lead coming from the side of the dizzy with a plug on the end. Where does this attach to the
coil?
Chris
The Magnificent 7!
A Badger
| posted on 30/3/04 at 09:30 AM |
The thin black lead from the dizzy goes to the coil -Ve, HT lead into the centre and the -Ve of the coil is connected to the ignition.
Setup the revcounter to the black lead and it works no problem.
Andrew
greggors84
| posted on 1/4/04 at 05:00 PM |
So there is no earth connection to the coil then? Also there is a plug like a small spark plug connector on the end of the this black wire, shall i
just cut this off and put a spade connector on.
[Edited on 1/4/04 by greggors84]
Chris
The Magnificent 7!
