Author: Subject: Help Who sells 2.8mm Superseal 4way connectors ?
posted on 1/9/09 at 02:08 PM Reply With Quote
I can't find a source for 2.8mm 4 way AMP Superseal connectors (must be 2.8mm to make a breakout connection) --- all the usual suspects only stock up to 3 way in 2.8.
blakep82
posted on 1/9/09 at 02:19 PM Reply With Quote
are these the right ones?
http://www.kojaycat.com/amp%20superseal%20connectors.htm
edit, sorry, 2.8mm, perhaps not
[Edited on 1/9/09 by blakep82]
________________________
Volvorsport
posted on 1/9/09 at 03:50 PM Reply With Quote
durite .
i may have some 4 ways but not 2.8mm .
www.dbsmotorsport.co.uk
getting dirty under a bus
balidey
posted on 1/9/09 at 04:27 PM Reply With Quote
I checked my Durite supplier, they don't list the 2.8mm above 3 way. So if they exist then chances are its OEM application only, so if you have seen them on a Ford loom, check with Ford. etc.
I don't suppose you want to use 2x 2 way?
