Author: Subject: A denso alternator question...
flak monkey
posted on 7/9/09 at 07:52 PM Reply With Quote
Anyone know how much current is required on the switched feed to the regulator in a denso alternator?
Sera
http://www.motosera.com
posted on 8/9/09 at 09:27 AM Reply With Quote
no, but I could measure it.
I am using small wire* that has not gone up in smoke; my guess would be less than 1 A.
update: quick google shows that someone is using 5 A fuse so looking good for my prediction!
* this is brown wire from mains cable so wouldn't be rated at more than 13 A.
[Edited on 8/9/09 by 02GF74]
flak monkey
posted on 8/9/09 at 10:45 AM Reply With Quote
Thanks for that.
Was just wondering as I would prefer to tee into another switched live if I can rather than run another cable from the ignition switch.
Part way through the re-wire and I realised I had forgotten it!
Sera
Ivan
posted on 8/9/09 at 03:12 PM Reply With Quote
Don't feel bad - theres nothing dense about that question.
Sorry I'll get my coat.
posted on 8/9/09 at 08:07 PM Reply With Quote
23.8 mA
I have a U-loop running to the coil power supply on the opposite side of the engine bay.
Didn't want to unravel the loom and remove the dash to wire it in "properly".
flak monkey
posted on 8/9/09 at 08:08 PM Reply With Quote
Jeez, not a lot then.
Thanks very much for that
Sera
