55ant
| posted on 11/9/09 at 07:12 PM |
Can't get the Horn!
evening all,
silly q, i have a removable steering wheel like so many others. now, i have the indy's MOT coming up and no horn?
how has everyone else dealt with this? just chucked a switch on the dash? i was thinking of using the washer jet button on the end of the wiper stalk,
its a tad useless without a windscreen.
cheers, ant
away from cars, now cycling and building TT bikes
scudderfish
| posted on 11/9/09 at 07:33 PM |
I've got a set of Escort stalks, horn on the left, washer on the right as I do have a windscreen. I can't see any reason why what you
want to do should be a problem.
rayward
| posted on 11/9/09 at 07:53 PM |
i did the same on my old indy, its fine for MOT, but you need to have a horn sticker covering the washer logo.
hth
Ray
SteveWalker
| posted on 11/9/09 at 08:11 PM |
No don't do it. Put the horn switch on the dash and connect up a temporary washer system - see if you can get the MOT guy in the face
RickRick
| posted on 11/9/09 at 08:49 PM |
sva guy was happy with a non working button in center of wheel, and tiny unmarked push button on the dash dunno for iva though
jacko
| posted on 11/9/09 at 08:57 PM |
Is it one of them things if its not fitted you don't have to have it working?
| posted on 11/9/09 at 09:14 PM |
No, you have to have a working horn....
RoadkillUK
| posted on 11/9/09 at 09:21 PM |
We put a pushbutton on the dash for ours ....
.... wait, we had a Sierra wheel on for SVA, pushbutton was post SVA.
Never mind, carry on.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
gavin174
| posted on 11/9/09 at 09:28 PM |
you didnt need a horn for sva..
but you do for iva
ReMan
| posted on 11/9/09 at 09:30 PM |
but you do for iva
No!
Next thing will be that legally treaded tyres are also needed for IVA!
bi22le
| posted on 12/9/09 at 12:34 AM |
Back to the OP!!
Am I reading your question right? Are you asking if it is ok to have a button on the dash for a horn? If that is the case than yes. If you want to
connect it to a stalk than you can but you dont have to. Its in reach and works, job done!!
If you want to know how to connect it to a stalk, use a multimeter on the unused wires, simples
Please read my ring story:
scudderfish
| posted on 12/9/09 at 08:53 AM |
If you are using Ford stalks, I've found in the garage a left hand one with a horn button on the end. Yours for free if you come and pick it
up.
55ant
| posted on 12/9/09 at 11:11 AM |
hi all, cheers for the response, im not bothered about where it is, push button is easy as i have one lying around and the two horn wires are easy to
get to. i was really asking if anyone had a set up that worked with the removable wheel (as in button on the wheel) and if so how you can wire this
in?
thanks for the offer of the stalk but i'll just check a push button on the dash, i have a new dash to put in over winter so this is just
tempory, need to get it through its mot, anbyone have a MOT list?
scudderfish
| posted on 12/9/09 at 12:53 PM |
Have a look at http://www.ukmot.com/manual.asp
