Author: Subject: Wiring up fuel pump
speedyxjs
posted on 18/9/09 at 07:44 PM Reply With Quote
Wiring up fuel pump
Has anyone got a diagram of how to wire up a fuel pump?
Sounds simple i know but i want to make sure iv got it right.
posted on 19/9/09 at 11:32 AM Reply With Quote
70+ views and noone is able to help?
looking at a modern car 84-91 Astra Haynes pump is wired as follows.
12 to relay to fuse to the pump.
the control for the relay comes from ecu.
for an old car - no ecu - wire the control to switched ignition.
... but for additional safety, the control would be wired to alternator output with an override at ignition starter posiiton - that way the pump does not run when the alternator is not turning.
in addition a hidden switch (poor mans immobiliser) can be added to the circuit.
