col
posted on 20/9/09 at 07:29 PM |
Mondeo strip
Some help required gentleman,(an ladies)
ive stripped a 95 mondeo for its engine,how much of the wiring will i need if im going to use bike carbs as its propultion device?
regards Col
big_wasa
posted on 20/9/09 at 07:32 PM |
If your making your own loom keep it all.
Failing that keep the plugs for the coil and crank pick up sensor.
austin man
posted on 20/9/09 at 08:26 PM |
wiring to the injectors all sensor wires, it also depends what ecu your going to use some people have used the mondeo one this obviously requires more
of the loom
big_wasa
posted on 20/9/09 at 09:11 PM |
If you wanted to run the mondeo ecu you will need the engine loom upto the plug near the battery. You will also need the antena from around the
column.
And a few other odds and sods.
Keep it all now as you can bin what you dont wont later.
prawnabie
posted on 20/9/09 at 09:13 PM |
Id take out as much as you can of everything. Dumping stuff at the tip is far easier than rummaging round a scrapyard in the middle of winter lol
blakep82
posted on 20/9/09 at 11:39 PM |
i'd just keep everything til you decide:
a) if you're making your own loom, or buying a made one
b) if you decide to reuse wires or use all new wires
personally, in order of preference, i would
1. buy a loom from someone who can make you a custom one (i know someone who does this so i'm fine)
2. make my own with all new wires
3. make my own with old wire
4. reuse old loom, taking out the bits you don't want
________________________
col
posted on 21/9/09 at 09:15 PM |
Thanks guys for you comments ive pretty well taken everything out.......the antena around the column?, is that the little plastic circle that goes
round the ignition switch?
