Author: Subject: Fuel Guage Screw Up
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
Building: a sense of satisfaction now things seem to work ok
posted on 13/10/09 at 11:39 AM Reply With Quote
Fuel Guage Screw Up
Hi All,
I finally got round to testing out my fuel guage set up last night which I have cobbled together from random components. And shock horror it doesn't work properly. I have a sender of unknown origins and a smiths guage. The sender operates from 50 ohms (empty) to 285 ohms (full). Unfortunately when connected to the smiths guage it works in reverse! Full shows empty and empty shows 3/4 full!
So my question is does anyone know if there is something clever I can do to reverse the signal or alternatively know of a cheap guage that works over that range?
Chris
tegwin
posted on 13/10/09 at 11:44 AM Reply With Quote
You can reverse the logic of ana analogue signal with some simple circuitry...
see here
http://www.maxim-ic.com/appnotes.cfm/an_pk/1129
www.verticalhorizonsmedia.tv
turbodisplay
posted on 13/10/09 at 11:45 AM Reply With Quote
Float type sensor?
Turn assenbly upside down so when full the float is where it was when empty.
Darren
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 13/10/09 at 11:49 AM Reply With Quote
The sensor is the 'float on the end of an arm' type. So I am stuck with it in it current position I am afraid.
Chris
x_flow57
posted on 13/10/09 at 12:10 PM Reply With Quote
Chris
Not necessaraly, I bent my "arm" through 180deg, adjusted the angles so it was accurate on empty and turned the sender upside down.
Nick
mistergrumpy
posted on 13/10/09 at 12:11 PM Reply With Quote
This happens on mine and what I do is when I see the arm heading towards 3/4 full I put more petrol in.
But seriously, no I just put up with it. It'll be a Winter fix I think.
posted on 13/10/09 at 12:16 PM Reply With Quote
Is it one of this type? (Smiths/Greenguages)
If so, you could try sliding the resistor box off the end, turning it over 180 degrees, and refitting it to the shaft. You'll probably have to bend the wire a bit to make it work again.
kendo
posted on 13/10/09 at 01:05 PM Reply With Quote
or, could you just swap the wires around on the gauge?
chris-p-duck
Contributor
Posts 256
Registered 16/4/07
Location West Mids
Member Is Offline
Photo Archive Go!
posted on 13/10/09 at 01:11 PM Reply With Quote
My sender is similar to that diagram except that the pivot is fixed to the upper mounting plate and not on a drop down arm.
Swapping the connectors round was my first though! Didn't make any difference unfortunately!
Chris
dunk3
posted on 13/10/09 at 04:03 PM Reply With Quote
Why not mount the fuel sender from underneath the tank, then it will read the other way round.
Staple balls
posted on 13/10/09 at 04:14 PM Reply With Quote
not insignificant risk of leaking?
DRC INDY 7
posted on 13/10/09 at 04:59 PM Reply With Quote
why not buy matching sender and gauge job done
Puddle Dodgers Club
RoadkillUK
posted on 13/10/09 at 06:59 PM Reply With Quote
Chris
Nick
This will fix it, just bend the arm.
0
0
Sorry for the ascii art, it's been a while
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
ianclark1275
posted on 13/10/09 at 09:47 PM Reply With Quote
solved my issues by using sender from a mini petrol tank i had lying about.
the senders are actually made by smiths so generally compatable
i also used a smiths fuel gauge.
i found i had to bend the arm to hit the Empty stop early to stop it reading past "E" as the travel on the mini tank is much greater and narrower at bottom, therefore resistor winding is a bit more Spaced out at the last 1/4.?
also - clean up the arm pivot as it carrys earth back to body of sender.
that last last sentence sounds like a crossword clue!
measure twice, cut once, scrap it, start again.
