Author: Subject: Relay wiring
corrado vr6
posted on 24/10/09 at 06:42 PM Reply With Quote
Relay wiring
Evening all, Some time ago i asked about how to go about making my lights switchable on my R1, using the R1 loom, as the lights come on with ignition.
It was suggested that I run the feeds to the lights through relays and switch the relays from the dash switches (Savage switches).
I have bought some micro relays but am unsure as to what i should put on each terminal of the relay ie: source, power, switch etc.
Heres a link to the relay im using below the main picture is a link to the diagram of the relay. Means nothing to me tho!
Any ideas?
Thanks in advance Greg
[Edited on 24/10/09 by corrado vr6]
posted on 24/10/09 at 06:51 PM Reply With Quote
to close the contacts, you need to apply 12 V to 86 and 0 V to 85.
for example 12 V to 86 and 85 to one end of a swith, the other end of the switch going to 0 V.
note that the positive voltage must be applied to 86 due to fitted snubber diode ( the black triangle with bar)
and the high current device is connected to either 30 or 87.
for example 12 to 30, 87 to say a lamp and other contact of lamp to 0 V.
[Edited on 24/10/09 by 02GF74]
redscamp
there is pin out under the picture on your link
mondeos are full of these relays and holder/bases
corrado vr6
posted on 24/10/09 at 07:07 PM Reply With Quote
Thanks for the replys, Just to be clear you when you say take the other end of the switch to 0 V do you mean earth?
http://r1indy7.wordpress.com/
RichardK
posted on 24/10/09 at 07:12 PM Reply With Quote
This may help you but also need to know the number of your pins which can found using the link under the picture of the relay in your link in the original post.
Your relay numbers below
Rich
Obviously substitute the fog lams for what you need and amend the fuse rating too.
[Edited on 24/10/09 by RichardK]
Gallery updated 11/01/2011
redscamp
posted on 24/10/09 at 07:16 PM Reply With Quote
0V = negative (-) = negative earth in a car with an alternator
corrado vr6
posted on 24/10/09 at 07:48 PM Reply With Quote
Wicked! Thanks everyone, It seems quite simple now! Hopefully im still saying this tomorrow
shortie
posted on 24/10/09 at 08:36 PM Reply With Quote
Hopefully this might help, I used savage switches as well.
http://www.dewweb.co.uk/indyblade/images/Indyblade_wiring_v17.pdf
Rich.
[Edited on 24/10/09 by shortie]
RichardK
posted on 24/10/09 at 08:44 PM Reply With Quote
Rich, that link is E404ing
cheers
Rich
shortie
posted on 24/10/09 at 08:51 PM Reply With Quote
Thanks, fixed now!
Rich.
posted on 24/10/09 at 09:13 PM Reply With Quote
NO!!!!!
That diagram is wrong for your relay - see what I said about the snubber diode.
If the relay has one fitted, and yours has, you cannot wire 86 to 0V and 85 to positive or you will have a short circuit.
IT MUST BE WIRED AS I STATED EARLIER.
swap over the 85/86 in the diagram and all will be well.
