Author: Subject: Brake warning test
speedyxjs
posted on 26/10/09 at 08:08 AM Reply With Quote
Brake warning test
Does the brake warning test need to be operable at all times?
I am not using the third point on the ignition normally used for turning the car over but this would mean it could only be used when the engine is not running.
adithorp
posted on 26/10/09 at 08:20 AM Reply With Quote
Normally it'd be from an ignition or accesory feed (IE. pos' 1 or 2 on the key).
I assume you mean you're useing a start button and therefore the start pos' on the key could be used for fluid test? It'd be down to the testers judgement, so I wouldn't. It'll cut the engine any time you test it. Just put it through the handbrake warning light.
http://jpsc.org.uk/forum/
Mr Whippy
posted on 26/10/09 at 08:34 AM Reply With Quote
As above, use the handbrake lamp and make it live with the ignition on
Dusty
posted on 26/10/09 at 08:52 AM Reply With Quote
Might be a pain to wire. Fluid level test usualy wired supply, bulb, switch and earth.
speedyxjs
posted on 26/10/09 at 09:47 AM Reply With Quote
Ok, thanks. I cant use the handbrake warning light 'cos i dont have one and dont have room to mount one.
speedyxjs
posted on 26/10/09 at 11:00 AM Reply With Quote
Is there any reason why it cant be wired to headlight flash, horn or the unused button on the indicator stalk for the trip computer.
I know the IVA manual says that buttons should be correctly labled though.
