speedyxjs
| posted on 30/10/09 at 02:52 PM |
Really basic indicator diagram
Im after a really, really simple indicator/hazard diagram. Iv done a search but cant find anything.
Also, how have you all joined the wires for all three indicators (assuming they all need to be joined together)?
Mr Whippy
| posted on 30/10/09 at 03:00 PM |
how about this -
speedyxjs
| posted on 30/10/09 at 03:06 PM |
Thanks whippy. Why is the relay before the indicator switch? Shouldnt the switch operate the relay?
Mr Whippy
| posted on 30/10/09 at 03:08 PM |
the relay doesn't know where it is in the circuit and putting it infront of the selector switch means you don't need one per side. Think
of the switch as just earthling the relay and allowing it to operate
[Edited on 30/10/09 by Mr Whippy]
speedyxjs
| posted on 30/10/09 at 03:16 PM |
Aaah, i see. Locost thinking there whippy
Mr Whippy
| posted on 30/10/09 at 03:22 PM |
note though that if you use indicator relays that at use bi-metal contacts then the flash rate for the hazards will be twice as long as the indicator
as its now powering 4 lamps not 2. So its best to use the microchip timer ones for LED's that their flash rate doesn't change with current
flow.
