tegwin
| posted on 1/11/09 at 11:01 AM |
Which coil pack?
I have a 1600 Pino using the 2.0l carbs....I think there is a mild cam in there somewhere as well...
I need to replace the coil as I think its worn out..
What coil should I replace it with? Is it just a normal 12V affair?
www.verticalhorizonsmedia.tv
ashg
| posted on 1/11/09 at 11:17 AM |
i have got a working 1600 pinto coil if you want to pay the postage.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
tegwin
| posted on 1/11/09 at 11:41 AM |
Would rather have a new one just for piece of mind, you know how it is!
Thanks though
prawnabie
| posted on 1/11/09 at 11:43 AM |
I think you just need to know whether it is electronic ignition or points. (thats assuming you left the bllast resistor out of the loom!)
tegwin
| posted on 1/11/09 at 12:11 PM |
Its electronic ignition... so no points in the dizzy...
Uses the standard sierra ignition loom....
prawnabie
| posted on 1/11/09 at 12:22 PM |
In that case ( someone will correct me I bet) you need to measure the voltage at the coil to see if you have 9 or 12 v
