Author: Subject: scource of multi core wire ???
steve m
posted on 6/11/09 at 08:08 PM Reply With Quote
I have some trailer 7 core wire, but am really after 12 core or more
Is this available ??
if so who does it
mangogrooveworkshop
posted on 6/11/09 at 08:11 PM Reply With Quote
caravan places
shortie
http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/multicorecable.php#trailer
austin man
posted on 6/11/09 at 08:14 PM Reply With Quote
have u tried the bay of e I picked up some 7 core just type in trailer cable
http://cgi.ebay.co.uk/12-Core-Cable-Wire-7-0-2-Lots-of-2M_W0QQitemZ380096393090QQcmdZViewItemQQptZUK_Burglar_Alarms?hash=item587f82af82
posted on 6/11/09 at 08:21 PM Reply With Quote
Even Hafords do 5 metres 7 core for a meerkat --- ie slightly less than a tenner.
shortie
posted on 6/11/09 at 08:22 PM Reply With Quote
yeah but if you read his post he wants 12 core plus!
iank
posted on 6/11/09 at 09:26 PM Reply With Quote
Two lengths of 7 core give 14 cores. Whether this is good enough depends on the job, but if it's being used to avoid making a loom it might be ok.
Otherwise as said VWP sell 13 way (one of which is a high current core) for £6.50 a meter (rather more expensive than running 2 lengths of 7 core)
Anonymous
spewing
posted on 6/11/09 at 09:33 PM Reply With Quote
http://cpc.farnell.com/jsp/search/browse.jsp;jsessionid=2DEOETQBXXUKOCQLCIRJNFQ?N=411+5014226&Ntk=gensearch_003&Ntt=yy+control&Ntx=&su ggestions=false&ref=globalsearch&No=0&getResults=true&appliedparametrics=true&locale=en_CC&catalogId=&prevNValues=411& originalQueryURL=http%3A%2F%2Fcpc.farnell.com%2Fjsp%2Fsearch%2Fbrowse.jsp%3Bjsessionid%3D2DEOETQBXXUKOCQLCIRJNFQ%3FN%3D411%26Ntk%3Dgensearch_003%26Ntt %3Dyy%2Bcontrol%26Ntx%3D%26suggestions%3Dfalse%26ref%3Dglobalsearch%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_CC%26catalo gId%3D
They only do up to 1.5mm sq per cable but other places do 2.5mm. You can even have 64 core.
Its all black with numbers printed on the black in white to identify the core and can be a bit of a sod to read them.
Its an option
Kev
Thurbs
posted on 6/11/09 at 11:33 PM Reply With Quote
Trailer cable
Vehicle wiring products is your place quick and reasonable postage and they do a 13 core cable
ashg
posted on 6/11/09 at 11:43 PM Reply With Quote
i got the 10 core vehicle wiring products one. dont forget all the earths can go to the body of the car and i cant possibly think of why you would need more than 10. i have used 8 and have 2 spare.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 7/11/09 at 11:34 AM Reply With Quote
Usual way to do earths is create an earth point at each corner of the chassis + earth 2 points under the scuttle and 2 in the engine bay.
For wiring the rear lights all you need is 5 core 6 if you fit a reverse light or 7 if you want left and right tail lights on a seperate fuse.
[Edited on 7/11/09 by britishtrident]
Confused but excited.
posted on 7/11/09 at 02:53 PM Reply With Quote
If you want multicore cable with 12 or more cores, search for 'Socapex'. It's used in stage lighting.
I don't know if I have any left. How much do you want, length wise?
