Staple balls
| posted on 16/11/09 at 04:29 PM |
Immobilisers.
Anyone have any suggestions/recommendations for a decent immobiliser for a locost type thing?
Not massively concerned about cost, but as always cheaper is good.
big_wasa
| posted on 16/11/09 at 04:38 PM |
Ive put a Toad touch key system in the locost.
Less than £30 on ebay
55ant
| posted on 16/11/09 at 05:31 PM |
will these touch key systems work on carb'ed engine (im trying to ask if it works by imobilising the ecu?)
away from cars, now cycling and building TT bikes
RickRick
| posted on 16/11/09 at 05:52 PM |
i got a transponder based system but in essense the same as touch key, it's a box of magic that contains 2 relays and isolates 2 circuits,
something like fuel pump and coil i think mine was limited to 16amps per circuit
big_wasa
| posted on 16/11/09 at 06:24 PM |
it will work fine on carbs. It just cuts the power to say the coil and fuel pump.
I had mine on the starter and coil.
55ant
| posted on 16/11/09 at 07:43 PM |
brilliant cheers, may get one of these, my dad has one on his afla and there really simple, and you can hide them nice and easily too.
speedyxjs
| posted on 16/11/09 at 07:44 PM |
Iv been looking into this too and have come across
this
Any good?
flak monkey
| posted on 16/11/09 at 08:47 PM |
I used one which has an RFID tag on they keys. No faffing with a touch pad or socket on the dash, just put your keys in with the tag attached and away
you go. No tag, no start
Like this:
Clicky
Sera
http://www.motosera.com
speedyxjs
| posted on 16/11/09 at 09:02 PM |
Your new avatar
Staple balls
| posted on 16/11/09 at 09:04 PM |
Ahh, that looks perfect, cheers flak.
Not so keen on the new girl though.
iscmatt
| posted on 17/11/09 at 12:07 AM |
Flak
That avatar is waaaay better than the old one!
interesting thread this as i have always toyed with the idea of getting an alarm and always thought that a system for a motorbike would be a good
route to go down, not really looked into any further than simply thinking about it though..
flak monkey
| posted on 17/11/09 at 07:23 AM |
Fancied a redhead for a change
Sera
whitestu
| posted on 17/11/09 at 08:47 AM |
If you get a transponder type like Flak suggests make sure you wire it up so that even when its raining and you have a helmet on you can tell it has
been activated.
I have one and on a couple of occasions I've spent time trying to start the car only to realise that the immobiliser is still on.
Maybe its just my immobiliser that is crap -its a Falcon one.
