carlknight1982
| posted on 22/11/09 at 04:22 PM |
Anyone brought these lights?
Any one brought a set of these lights, Im thinking it could go either way at that price, also are they IVA ok?
Linky
Logic will get you from a A to B
Imagination will take you everywhere.
theconrodkid
| posted on 22/11/09 at 04:26 PM |
they are from export land rovers afaik,i used them for my SVA with no probs but the bulb holder does poke out a long way so you may need a spacer like
westies use
who cares who wins
pass the pork pies
Daddylonglegs
| posted on 22/11/09 at 04:44 PM |
I bought a set like tha (as single units) at Stafford last year. Cost me £22 for the lot iirc.
Not sure that is such a bargain on the bay?
Mind you, mine might not be the same quality as those but they seem OK to me.
Michael
| posted on 22/11/09 at 05:39 PM |
I brought a set (sold singular) from Premier looms, but took them back as like as felt they would sit to close to the wheel if surface mounted.
I know have Multi lamps similar to Caterham.
dogwood
| posted on 22/11/09 at 05:54 PM |
No prob's on mine.
I think AshG got a set from CBS and modded the socket so I did'nt sit so close to the wheel
FREE THE ROADSTER ONE…!!
mr henderson
| posted on 22/11/09 at 06:02 PM |
quote: Originally posted by carlknight1982
are they IVA ok?
Make sure the fog and reverse lights 'face squarely to the rear' widely interpreted to mean they need to be vertical, difficult to achieve
on your average seven. Even the angled holders you can get from CBS etc don't allow enough angle to get them vertical.
andrew.carwithen
| posted on 22/11/09 at 06:44 PM |
Got same fitted on mine and passed SVA fine.
Although I had to modify them as even with the mounting plinths, the tyre would rub on the indicators. (The tail lights were ok as they are inboard of
the tyres.) So had to shorten the bulb holder section and remove the silicon to enable me to bend the contacts at right angles (before resealing with
silicon) to give the necessary clearance.
mr henderson
| posted on 22/11/09 at 09:30 PM |
SVA ok in your case, IVA maybe not OK. In the IVA manual it does say "must face squarely to the rear" so if they slope the tester would be
within his rights to fail them (although maybe he wouldn't)
