Paul (Notts)
| posted on 24/11/09 at 05:45 PM |
Air Temp Sensor - Megasquirt
Looking for a cheep source ( online) for an Air Temp Sensor to use with megasquirt 1
Any help appreciated..
Paul
sebastiaan
| posted on 24/11/09 at 06:04 PM |
Buy it now!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330380270584
That'll do, you just need to figure out the curve (boiling water & ice & 20 degrees inside and measure resistance) and input the correct
values into megasquirt (using easytherm).
Paul (Notts)
| posted on 24/11/09 at 06:42 PM |
Link not working....
paulf
| posted on 24/11/09 at 09:27 PM |
Your better off to get the correct one to match the standard ECU , lots of people have problems with easy therm.The other way is to change the bias
resistor on the MS board to suit , a ford sender needs a 27k resistor to work correctly.
Paul
quote: Originally posted by sebastiaan
Buy it now!
