rich201283
posted on 13/4/04 at 06:25 AM |
which relay on the esc2 do i need?
Which 2 relays are they and where are they located, the 2 relays that are used in the ignition setup using the esc2 method
posted on 13/4/04 at 09:22 AM |
Go on then... give us a clue what you're onna-bout???
rich201283
posted on 13/4/04 at 09:56 AM |
where are they located in a sierra
There are 2 relays that are used in the ignition system within the esc2 setup, i need to know where they are located at in a sierra
posted on 13/4/04 at 10:10 AM |
Sorry, now you explain I have absolutely no idea to what you refer.
We didn't use them... left them where they were and used a bike engine.
Fifer
posted on 13/4/04 at 11:34 AM |
I give up too.
What is esc2 ?
posted on 13/4/04 at 12:18 PM |
esc2 is the name of the ign module used in some sierras. The relays will be in the fues box. You will have to follow the wires back, or work out the
code.(if there is one)
