redders33
posted on 4/12/09 at 08:39 PM |
megajolt
Hello, I am having trouble getting my megajolt to run on my lap top keeps saying it cannot open port? any one good at that sort of thing? also trying
to wire the tps up and not sure where the + and - go????? cheers Nick (2.0 silver top zetec running R1 carbs and megajolt)
dhutch
posted on 4/12/09 at 08:53 PM |
I have to admit, having had the whole thing go without a hitch from start to finish i proberbly not the person to advise.
- However, to start, are you useing a laptop with a com port (i was) or with a usb adapter.
Daniel
whitestu
posted on 4/12/09 at 09:27 PM |
Check you are trying it on the correct port?
Try all the ports listed and see if any work.
Alternatively you can see in control panel [assuming it is XP] which port is being used.
Danozeman
posted on 4/12/09 at 09:45 PM |
On the autolabs site theres a java application you may need to install to make it work. Mine needed it.
Dan
austin man
posted on 4/12/09 at 09:58 PM |
Is your Com port set as port 1 ? My GEMs unit isnt recognised unless the port is set to port 1.
woolly
posted on 5/12/09 at 12:12 AM |
can't add much to the com port problem apart from trying another usb converter. i have 3 which will work first time on one computer and not at
all on another. ?
with the TPS i took it of the carbs and on to the bench and connected a small 9v battery to the two outer pins and read the volts on the centre
one.
the signal pin should have a rising voltage when the throttle is opened.
turned the outer connections around till correct.
what was + bat = vref
- = ground
signal = TPS input.
woolly
snapper
posted on 5/12/09 at 09:08 AM |
This happens to me offten as i use an RS232 to usb adaptor, Megajolt tuning prog only uses COM ports 1 to 10, some times the adaptor appears on a
higher number.
If i can,t connect i go to control panel, device manager, check the COM port the usb adaptor is attached to and set the Megajolt tune to look at that
port, this usually works.
Sometimes the usb adaptor is on a port higher than 10, usually because the computer still has COM ports allocated from other times i connected the usb
adaptor of other devices. I then carefully dlete the device from COM port 1 to 10, making sure not to delete a computer specific device.
This all sounds more complicated than it is, and if i can do it you can.
I eat to survive
I drink to forget
mediabloke
posted on 5/12/09 at 11:24 AM |
The problem is, as others have said, between your PC and the megajolt.
Sounds daft, I know, but I get the same error when I start the software without a 12v feed to the megajolt. I'd check that first, then try
another port.
[Edited on 5/12/09 by mediabloke]
redders33
posted on 5/12/09 at 10:08 PM |
thanks for the replies...I am using a usb adapter on the megajolt I only get options of ports up to 20 but the two ports on the back of my laptop are
21 and 22? The two ports on the side are 19 and 20 but niether of these will open?
