corrado vr6
| posted on 6/12/09 at 11:37 PM |
Do i need reflectors?
Hi im going to order some ultrabright LED rear lights mix and match, Have done a search and im now confused as to what to do, basically to cut a long
story short do i need reflectors at the rear?
I am thinking of having this setup but as you will see no reflectors although i could add some to the rear panel if required, will this be ok for IVA
Thanks Greg
http://r1indy7.wordpress.com/
Miks15
| posted on 6/12/09 at 11:40 PM |
99% sure you need reflectors
Steve G
reflectors are needed if they arent built into the lights you buy. Be careful of making sure they have radiused edges if they protude more than 5mm i
think it is
corrado vr6
| posted on 7/12/09 at 12:24 AM |
Ok thanks guys for the extra couple of quid i will order a set of reflectors as well, i will also be using the carbon fibre effect housings so
radiuses hopefully shouldn't be a problem
Miks15
| posted on 7/12/09 at 12:29 AM |
just out of interest what lights are they?
corrado vr6
| posted on 7/12/09 at 12:34 AM |
Ultrabright LED Mix and match range on this page about 1/4 of the way down the page linky
not working out very locost, but look the nuts!!
[Edited on 7/12/09 by corrado vr6]
| posted on 7/12/09 at 08:24 AM |
so you gonna get separate reflectors?
how about ditching the chrome ring - does nothing apart from adding excess weight and make reverse/fog one unit and have relefecotr outer ring on
tail lamp, for example?
corrado vr6
| posted on 7/12/09 at 10:49 AM |
That setup would work really well, but as far as I can tell reverse/fog lights only come as inners and not outer so would not work unless I'm
missing something?
omega 24 v6
| posted on 7/12/09 at 12:41 PM |
Why not get the stop and tail outer light combination and use an outer reflector on the outer lights.
if you see what I mean.
bigfoot4616
| posted on 7/12/09 at 07:01 PM |
the lights are well worth the money, i've got stop tail inners and indicator outers. look really good mounted flush.
try and get some stick on reflecters then it wont leave any holes when they fall of after IVA
bj928
| posted on 8/12/09 at 03:05 PM |
heres my rear lights all led, have 2 complete sets so may use the second fog as a 3rd brake, and keep the 2nd reverse as a spare.
Angel Acevedo
| posted on 8/12/09 at 08:46 PM |
That´s more or less what I want,
How much did they cost?
Just for reference....
As I live in Mexico.
bj928
| posted on 8/12/09 at 09:53 PM |
they were free from a friend, they are fitted to the back of trucks and buses, but i can't find them listed anywhere, found some nice lights in
the link below though
http://www.pakfeifer.com/catalog/product_info.php?cPath=225_193_236_716&products_id=12209&osCsid=2d
